How to use remote control from the TV-card?
hoshino
My TV-card as Magic-Pro ProHDTV Deluxe
but i think it should same as Kworld DVB-T PE310
It come with a remote control by directly plugin to the TV card.
And it work well with Totalmedia
I have already tried to map the key in by clicking "Learn" in Settings>Option>Input
However, the DVBViewer give me no response even I clicked any buttons on the remote control.
Does DVBViewer support for the remote from my TV-card?
or I missed any steps instead?
Thx
Hoshino
Thx
Hoshino
You could look for a plugin for the remote control in the members area.
I wanted my hauppage remote to do a number of things such as Swicth between monitor and LCD TV, control DVBViewer, Control Power DVD.
In the end i settled for using a program called Event Viewer. You can map your keys any way you like and the program also has pluggins for operationg certain programs to give you a pre-set list of commands which helps.
It takes a bit of playing with to understand how event viewer works but read up on it, have a play, and once you get to grips with what you need to do it should do what you want and more.
