DVBViewer 4.1.1 User data error
ossun
after the update 4.1.1 DVBV error says userdata control and closed...please halp me..thanks.
Please check you userdata. Make sure you entered the userdata, you used for downloading from the membersarea, correctly in the setup.
Same here. I upgraded 4.0 version to 4.1.1 and got that message after ~30 min watching. Userdata is entered 100 % correctly.
Ok, here is that supporttool output and main components of my computer.
Intel Q6600
Gigabyte GA-P35-DS4
8800 GTS 512 & 182.50 WHQL
4GB DDR2
TV card - Terratec Cinergy 2400i DT & 1.1.0.284 drivers
OS Windows 7 RC 64bit
Version 4.0 worked perfectly, I had absolutely no issues with it.
Edited by yakuza
same error in windows 7 rc x86...
intel core2 quad 8200
asus p5q
palit 9600gs
TV card - skystar 2 tv-pci
OS Windows 7 RC 32bit
Edited by ossun
Ok, problem solved here with fully clean install.
Funny thing was that error message popped out EXACTLY in 26 min intervals.
