dvbviewer will only scan 1 transponder
hi all im new to dvb cards but not to the sat seen i having some trouble setting up my skystar hd2 and dvbveiwer pro i have got it to turn my motor and scan the sats but it only seems to only scan 1 transponder like on 28e it only picks up channel 4 and film 4 more 4 and on 1w it only picks up tv4 film tvsport etc not sure whats happening as dvb dream will pick up everything but cant get it to turn the motor the scan field seems to be correct like 1 to 90 but only seems to scan 1 any help would be appreciated thanks guys
I faced the same problem - with SkyStar-HD2 DVBViewer would stop after scanning the first transponder (In "Range Mode"). One tedius option was to scan each transponder in "Frequency Mode". But then S2 transponders were not scanned. Finally I scanned channels with TranEdit... which scanned successfully nearly all transponders. However, it did miss two S2 transponders which were picked up directly by DVBViewer's scanner.
So use both. Mainly TransEdit & for missed transponders try DVBViewer itself.
