HD Canal Digital nordic & Transedit
karlceasar
I can't get the S2 channels to work - it's all black.
A while ago I managed to loate the channels using transedit - but when I scan now I hardly can get it work, it's really a matter of luck if it find any channels...
I'm using a Floppydtv, Vista and Q6600 processor and ATI HD4850.
All SD channels works great but when it comes to the S2 the logtext says no PID found nor CAT..... According to the ini files of kingsofsat for instance, all settings should be correct.
I've the disabled the "open whole transponder" option as well.
Do anyone have suggestion what to do to solve this?
