stasimon Posted May 12, 2009 Posted May 12, 2009 Hi First sorry for my bad english! I have some problem with DVBViewer Media Center. Download from members area OSD Menu Editor, start edit osd menu. I can move/add/hide media center menu but when I try to add some extra software, ex. games - it doesen't work! It's work only when I install this program in DVBViewer default folder! How Can I add ex. new games or programs to menu media center? If I good remember 2-3 weeks ago I found solution how to do this (5 games which I add before works fine) but I reinstall my windows and lost all links! Hope you understand! Big thx. for help! Quote
Tjod Posted May 12, 2009 Posted May 12, 2009 If you use OSD Skin concinnity 3D chage the OSD Skin. Quote
stasimon Posted May 12, 2009 Author Posted May 12, 2009 If you use OSD Skin concinnity 3D chage the OSD Skin. I use MediaStream OSD Skin (Xbox Media Center for DVBViewer) Quote
Tjod Posted May 13, 2009 Posted May 13, 2009 Please post a support.zip with the not working menu entries. Quote
stasimon Posted May 13, 2009 Author Posted May 13, 2009 Please post a support.zip with the not working menu entries. I try on default skin to... same problems! It's my menu file, try to add MAME emu games and normal games. support.zip Quote
Tjod Posted May 14, 2009 Posted May 14, 2009 Here it works, may be you choose the wrong windowdef.xml. You should edit the one in the configuration folder. Quote
stasimon Posted May 14, 2009 Author Posted May 14, 2009 My Media Center OSD Menu works fine, but when I try to start any games from PC or ARCADE, it didn't work! Strange, but when I copy all files from folder MAME to folder DVBViewer - it work's! All files must be in DVBViewer, but it's dificult to keep all files without any other folders in DVBViewer folder. OSD Menu work fine, it's look like DVBViewer block another application which I try to open. I can make some video and put in youtube if you don't understand me...? Quote
Tjod Posted May 14, 2009 Posted May 14, 2009 Yes now i understand, I try it with some programmes and it worked. But I have no dea what went wrong on your PC. Quote
stasimon Posted May 14, 2009 Author Posted May 14, 2009 (edited) Can you put here your osd file with added 3-4 programs, like emu MAME or another short program which open on full screen? (with files in separate folders on disk D) I will check your osd file on my computer... Don't know whats happen, I try on 2 different Windows XP with SP3, when I try MAME, it's start loading room and close MAME window - but if I try this without DVBViewer - works normal! the same is with games from section "Pistolet" from my OSD Menu, have error, it's looks like "Can't open file" or "File doesn't exist" but when I try open from the same file but without DVBViewer, every time works ok! I'm confused, maybe you have any idea? Just checked, when I try open MAME emu games from DVBViewer, It's show "Required files are missing" but all files exist! So it's not MAME problem... Edited May 14, 2009 by stasimon Quote
stasimon Posted May 18, 2009 Author Posted May 18, 2009 Hello again, I checked DVBViewer + my OSD MENU file on 4 different computers - my laptop, my girlfriend, my frined desktop and his girlfriend laptop. (Windows Xp and Vista 32bit) On all computers doesn't work, so I think problem is with DVBViewer? Also I edit new Osd Menu file and add only 3 games (2 mame + 1 Pc game), again the same problem! Can someone help with this? Quote
stasimon Posted August 3, 2009 Author Posted August 3, 2009 I try new DVBViewer + OSD Menu Edit = still the same problems! I edit new windowdef.xml from DVBViewer 4.2.1. 1st I add to menu "Games" 1 MAME emu games (put MAME folder in another hard drive) - doesen't work! Next I put all files from MAME folder to DVBViewer folder and try again. Now everything work! My questions is, why MAME emu or another PC Game works ONLY when I put all files (or install) to DVBViewer folder? When MAME files are in different folder or games is install in another folder - doesen't work! Why? Quote
Olliber Posted August 3, 2009 Posted August 3, 2009 I try new DVBViewer + OSD Menu Edit = still the same problems! I edit new windowdef.xml from DVBViewer 4.2.1. 1st I add to menu "Games" 1 MAME emu games (put MAME folder in another hard drive) - doesen't work! Next I put all files from MAME folder to DVBViewer folder and try again. Now everything work! My questions is, why MAME emu or another PC Game works ONLY when I put all files (or install) to DVBViewer folder? When MAME files are in different folder or games is install in another folder - doesen't work! Why? Hi, I think the program looks only in his own programdirectory (it can`t scan everytime the hole harddisk). I don't understand if you put your files directly to eg c.\DVBViewer\ or if is works if you used subdirectories... if is possible than you should try symlinks (softlinks) in Vista (c:\>mklink /d "C:\DVBViewer\games" "D:\archiv\mame" ) or junctions links in Xp (C:\>JUNCTION.EXE "C:\DVBViewer\game" "D:\archiv\mame" Maybe it is a good idea you add your Mame folde to the system path variables, so that windows found them better. Best regards Olliber Quote
stasimon Posted August 3, 2009 Author Posted August 3, 2009 I install DVBViewer in "C:\Program Files\DVBViewer", when I put emu mame files in "C:\Program Files\DVBViewer" - works fine, when I put it in "C:\Program Files\DVBViewer\MAME" - it doesn't work. How to do symlinks (softlinks) in Vista? I use normal XP and sometimes Vista... Quote
Olliber Posted August 4, 2009 Posted August 4, 2009 I install DVBViewer in "C:\Program Files\DVBViewer", when I put emu mame files in "C:\Program Files\DVBViewer" - works fine, when I put it in "C:\Program Files\DVBViewer\MAME" - it doesn't work. Hi, than I think the links doesn't help. Can u upload some games and one emu, so that I can test with this? Have you alreasy tried to add the paths in the system environment paths? Best regards Quote
stasimon Posted August 4, 2009 Author Posted August 4, 2009 This is emu MAME with game Mortal Kombat 3 (mk3) - you can try start this from DVBViewer menu: http://rapidshare.com/files/263767493/MAME.zip I use now Win XP SP3 and don't know how "add the paths in the system environment paths"? I think problem is with DVBViewer - I install 2 weeks ago Media Portal and emu works, I want know why don't work in DVBViewer... Quote
stasimon Posted August 12, 2009 Author Posted August 12, 2009 @Olliber did you try this emu? Anyone can help? Quote
stasimon Posted August 13, 2009 Author Posted August 13, 2009 Still with this problem, I already add paths with Games or Emu to the system environment paths but it not help! Emu or another programs, games only work when I put all files to the DVBViewer folder. If I create another folder in DVBViewer folder - doesn't work. Work only when copy all files to the main DVBViewer folder. I'm sure is not problem with my PC, I checked this on WinXP and Vista on my laptop and my girlfriend. Also checked on my friend PC with WinXP - always the same error. I like DVBViewer Media Center but don't understand why this not work? Quote
