cobson Posted May 14, 2009 Posted May 14, 2009 If .mpg format is selected for recordings, does that mean it is being recorded as a program stream rather than a transport stream ? What does mean (if anything) regarding reliability / quality of the recording for: 1) Playback in DVBViewer 2) Network streaming the recording 3) Conversion for DVD archiving Quote
IRa Posted May 14, 2009 Posted May 14, 2009 For 1-3 there shoud not be any difference (for 3 it may depende what software you use to create DVD) If you want keep DVBsubtitles, teletext subtitles and separate audio tracks in your recordings then you need TS. MPG has some advantages if you want use your recordings in some other applications (iPod etc), it is more supported . Quote
