restimek Posted May 14, 2009 Posted May 14, 2009 (edited) Hi I have a problem Yestarday i instal windows 7 64 bit RC. Before i used windows xp DVBViewer 4.1.1.1 and power dvd 9 codec for HD channels becouse this codec used nvidia pure video HD. In windows 7 DVBViewer do not see power dvd codec - only divx h264 and microsoft codec. What i must do to fix this problem? Or is any other codec whoes can use nvidia pure video? In divx and microsoft codec's CPU usage is 60 % ps. sorry if i write any mistakes but my english is not good. Edited May 14, 2009 by restimek Quote
Tjod Posted May 14, 2009 Posted May 14, 2009 The DVBViewer needs 32 bit Direct Show filter. If the Decoder are 64 bit or Media Foundation they will not work. Quote
ter9999 Posted May 15, 2009 Posted May 15, 2009 Hi I have a problemYestarday i instal windows 7 64 bit RC. Before i used windows xp DVBViewer 4.1.1.1 and power dvd 9 codec for HD channels becouse this codec used nvidia pure video HD. In windows 7 DVBViewer do not see power dvd codec - only divx h264 and microsoft codec. What i must do to fix this problem? Or is any other codec whoes can use nvidia pure video? In divx and microsoft codec's CPU usage is 60 % ps. sorry if i write any mistakes but my english is not good. Most recent trial versions of PDVD9 do not have H.264 filters built in. You can try earlier PDVD versions. PDVD9 is 32-bit software, so its filters can be invoked by DVBViewer. Quote
restimek Posted May 15, 2009 Author Posted May 15, 2009 (edited) @ ter9999 my power dvd is 32 bit ultra version so it have h264 codec.... do you know any other codec who use nvidia pure video HD?? Edited May 15, 2009 by restimek Quote
fundom Posted May 15, 2009 Posted May 15, 2009 Try ArcSoft Video Codecs...MPEG2, H.264 & VC-1, all in one! Quote
Milly Posted May 16, 2009 Posted May 16, 2009 Try ArcSoft Video Codecs...MPEG2, H.264 & VC-1, all in one! Strangely for me (W7 RC1 64bit) when i had "use system default" showing BBC HD was running fine with only 20% cpu useage... Only problem was no audio due to ac3!! I've still only put ac3 filter in tho for sound as yet not needed CoreAVC!! Quote
restimek Posted May 16, 2009 Author Posted May 16, 2009 what is your CPU? My is core 2 duo E 6600 2.4 Ghz Mayby you have stronger CPU Still i have problem with HD channels Quote
