HD-channels almost always crash
gakke
When I try to view HD-channels I 9 of 10 times just get a black screen with no sound or I get mosaic-strips with soundnoise. This is making DVBViewer totally useless. I have Windows 7 RC with FireDTV. Using version 4.1 at this time. Before I installed Win7 I had Windows XP and DVBViewer 3.9. I still had the same problems, but not so much. It was usable.
I have tried different codecs with no better results. Starting the CI-modul program does nothing. I'm using Dilog conax cam.
I'm using 64-bit Windows 7 RC, using ffdshow audio filter for mp2/ac3 audio, and PDVD9 MPEG2/H.264 video filters for video and EVR for video renderer. It's very stable, no crash at all. You can try these filters and EVR.
I can't get Powerdvd9 codec to come up in the codec-list in 64bit. It got something to do with the direct show-filer who needs to be 32 bit. Don't know how to fix that. EVR did'nt improve anything. I have allready tried all the renderers. I used powerdvd9 in Xp and 3.9 with no less crashing then other codecs. It must be something else.
