Hauppauge WinTV HVR-4000
DeepSpace9
Hi all,
I'm planning to change my good old SkyStar 2 with a new receiver card that implement also the DVB-T and DVB-S2.
after looking around a bit I'm thinking to go for the Hauppauge WinTV-HVR-4000.
This is an expensive card and I care to stick to DVBViewer. So before buying it I wish to be sure that this device is (or will be) fully compatible and supported by DVBViewer.
Now, even if I've found around some good feedback about using the HVR-4000 with DVBViewer, this card is missing from the list of DVBViewer's supported devices (ref: http://www.DVBViewer.com/en/index.php?page=features)
My questions are:
1 - Is (or will be) this card officially supported by DVBViewer?
2 - Is it a good choice? (aiming to have DVB-S/S2/T)
3 - What can be a better alternative solution, keeping in mind that I do want to stick to DVBViewer as a software for viewing tv-channels? (but using two separate devices for S/S2 and T would not be a problem)
Thank you
DS9
Hi all,
My questions are:
Thank you
DS9
First, excuse me for my bad english, im spanish and i need a little of practice :wacko:
I've got a HVR-4000 and works perfect in all modes, i use CoreAVC codecs for hd, and cyberlink codecs for mpg2, also works great with native codecs of windows 7 :wacko:
  • 3 weeks later...
First, excuse me for my bad english, im spanish and i need a little of practice :D
I've got a HVR-4000 and works perfect in all modes, i use CoreAVC codecs for hd, and cyberlink codecs for mpg2, also works great with native codecs of windows 7 ;)
Hi, here from spain too...
Which drivers are you using for the HVR-4000?
Thanks and best regards
Mayankel
