Eject shorcut
dyter
There is a action, 12299, that eject the CD (see all actions in "actions.txt" file in the main DVBViewer folder) that can be easily added among the other predefined Input and assigned to keyboard or remote... follow me:
• go to Settings / Options / Input
• go to end of list an select the last command
• click "Add", name the action "Eject CD" then click "Ok"
• press the "E" key on the keyboard and "Eject CD" action with his number will appear on the left
• click "Add" (as you can imagine you can add more than one action per "command"...) and "Ok"
• click on "Learn" button
• select the "Eject CD" action
• push the desired remote button and/or keyboard key
• unpush "Learn" and click "Ok"
...you and your remote are ready to go!
:P
@Tjod: gosh, that fast!...
Edited by Gioxy
Thanks !
This dvb software is very powerfull !
