Exit
cobson
I'm using a remote control, which has a button setup to call the Exit function. I've noticed that if this is pressed whilst a channel is being viewed it doesn't bring up the normal OSD-type exit confirmation window, but instead brings up a Windows-style confirmation window which can be controlled by keyboard/mouse but not with a remote. Whilst this is being displayed, if I use the remote to bring up any OSD screen in the background the Windows-style confirmation changes into an OSD-style confirmation. Does this happen to everyone ?
I can get around this problem by setting up a new Input command which does the sequence OSD-Menu, then Exit. I then tried adding OSD-Left and OSD-OK to see if I could exit without having to confirm but this doesn't work. Is there another way of exiting without confirmation (whilst leaving the PC on) by remote control ?
Doesn't happen to me, in any situation, if press my button set-up for exit I get the OSD exit yes/no box. Sorry.
Interesting. I'm using the Recording Service ans also DVB Starter. I'll have to see if either of those is the cause.
Ah, just spotted the Close DVBViewer command...
