Run DVBViewer on return from standby?
uglyned
Is there an easy way to have DVBViewer run when the PC returns from standby? I want TV, not Windows!
Thanks
You can use some specific freeware app like Hibernate Trigger...
You can also set DVBViewer to open tha last channel you are viewed (Settings / Options / TV + Radio / Tune last channel on start) or put in the command line a fixed channel to open with (C:\Prog...\DVBViewer "-cExact channel name")
... oder einfach den Taskscheduler von Hartwig im Download, der macht das ganz nebenbei ebenfalls.
