Oreste Posted May 21, 2009 Posted May 21, 2009 i got an ASUSTeK Tiger-S/DVBS Hybrid Capture Device this is a 3in1 cad with DVB-S, DVB-T and analog TV they work perfectly with cyberlink powercinema but not with DVBViewer. I have a skystar2 for DVB-S that work without problems but i also want DVB-T and i tried this Asus 3in1. My intention is to remove th skystar2 and do all work with only one card, the Asus. After some problem i've reinstalled DVBViewer and assigned only group channels A to DVB-S and group channels B to DVB-T. With this trick i can scan all channels on DVB-T And DVB-S. The problem is: if i can watch a channel and then switch to a channel on a different reception system (eg: DVB-T to DVB-S or DVB-S to DVB-T) DVBViewer notice me 'no hardware' error. I can only watch channels on the same system! To watch a channel on the other system i do close the graph and DVBViewer freeze then i reboot the PC and i can run DVBViewer without a channel selected then i can switch to the other TV system. Sorry for my english. support.zip Quote
Lars_MQ Posted May 21, 2009 Posted May 21, 2009 Most likely because it is an hybrid card. Try editing the hardware.xml and set for both devices the DeviceNr to 1. Quote
Oreste Posted May 22, 2009 Author Posted May 22, 2009 Many thanks! Yes, obiouvsly it's a hybrid card. Seem to work with this trick. Later, when i have more time, i do more test. Quote
