problem dvbviewer 4.1
txus000
Hi I have a problem with the new version, 4.1, is closed after some time of operation, tells me to reinstall the correct user data
with previous versions I have not had this problem
I can do
Excuse me, but I do not speak English, this is a translation of google
Your google translation is quite fine, the problem might be caused by the installation procedure. Please install the application with the same account you used for downloading.
Peter
I used the same account, and when I asked the user datod put them
have to do the clean installation?
I refer to first uninstall the previous
thanks for answering
I know no one answer, nor moderators or administrators or programmers DVBViewer ??????
I am going to buy it
having free software
if I'm stupid
Remove 4.1 completely.
Go to Memebers Area
Download Version 4.1.1
Install
Make sure to enter correct Name and Password-DO NOT COPY and PASTE
Enjoy
V4,1 was a bit flimsy with the Copy-Protection
Greetz
Pinbot
well I solved the problem by uninstalling everything and reinstall
you have not had to write it because it has maintained
thanks
