No Audio on DVD Playback
EnChO
Hi i've tested 3.9, 4.0 and 4.1 versions of DVBViewer with k-lite codec pack and powerDVD installed and always get same problem with all my DVD's no audio AC3 5.1, AC3 stereo or DTS mode, i can play correctly on PowerDVD, VLC and Windows Media Player :wacko:
Any Idea??
Sorry for my bad english :/
Thanks for Help me :wacko:
Edited by EnChO
Any Idea??
Why do you use k-lite codec pack?
PowerDVD should be sufficient
I have read in several Forums that k-lite is a no-no
Try this one. Don't forget to select it in the DVBViewer options:
http://ac3filter.net/projects/ac3filter
Thanks , AC3Filter fix the problem!!! i don't understand why PowerDVD audio codecs does not work in DVD mode... ¿ maybe a Codec Bug? or a Progam Bug?
Maybe Cyberlink doesn't allow AC3 playback in other applications due to licence restrictions, dunno...
In their latest updates Cyberlink disabled any use of their codecs in other applications, hopefully MPC-HC will work on making their decoder useful for H.264 TV o:).
Edited by dvbrewer
