BobrB Posted May 25, 2009 Posted May 25, 2009 Hello I have in EPG window old EPG data. When I start DVBV it usually shows EPG info (starting time and name) about running and next program. When I open EPG window to see another TV programs It shows me EPG data a few hours or days old. I use DVBV GE --> I downloaded new version (2.7.2) and configured that, but it appeared too after about 10 minutes. I tried to change saving/not saving EPG data on to HDD but nothing changed:-( Worse problem is that sheduled recordings do not work becouse of that non-actual datas in EPG Configuration: Windows Vista Home Premium SP1 DVB-T Technisat AirStar 2 PCI DVBViewer GE 2.7.2 Do you have idea what I can do? Quote
Griga Posted May 25, 2009 Posted May 25, 2009 When I open EPG window to see another TV programs It shows me EPG data a few hours or days old. Select EPG Window -> Filter -> From now. Quote
BobrB Posted May 25, 2009 Author Posted May 25, 2009 Select EPG Window -> Filter -> From now. I will test, but I was sure I tried - I will inform you Quote
BobrB Posted May 25, 2009 Author Posted May 25, 2009 Select EPG Window -> Filter -> From now. I had this setting. Nothing changed. When starting it checks "EPG data load" but at this moment it starts with EPG data from Sunday 6:45 :-( Quote
BobrB Posted May 25, 2009 Author Posted May 25, 2009 check your systemtime. You are right. I had correct day and time but one months later. It is so stupid mistake... I feel ashamed of that. I spent many hours to solve that but I never dreamed of it THANK YOU Quote
