dvb-t and dvd sometime are not fluid
ardua97
i bought a lcd tv
a samsung le-32a656a1
a lcd full hd 32''
connect to a htpc with a dvi==>hdmi cable
to the video card SAPPHIRE HD 2400 XT 256MB
with DVBViewer 4.1
I noticed that the vision of the dvb-t and dvd movies sometime is not fluid
Probably it appen even before (with the television cathode ray tube), but now with the new television i pay more attention
i use vista as SO
and in directx option in dvbviever
as render video is set :EVR
and as decoder vider: Cyber link video/sp decoder (PDVD 7)
There are better decoder?
is difficult to me to explain me in english (i'm italian)
sometime frames hangs for a bit
What kinnd of CPU do you have?
For HD TV i would recommend a dual core Intel of atleast 2.6GHz
Use windows built in decoder instead.
If it's HD channels that are affected, the ultimate solution is to install Windows 7.
You will get codec for both SD and HD channels.
I'm running this myself on 2 HTPC's and will newer go back to slow and choppy vista again.
i bought a lcd tv
a lcd full hd 32''
with DVBViewer 4.1
Do you have the latest version of ATi Catalyst?
  • 3 weeks later...
i have a
AMD Athlon 64 X2 Dual Core Processor 4800+
and 4 gb ddr2 667 MHz
it is enough?
with my motherboard i'll cam mount
a PHENOM 9950 Quad Core 2.66Ghz AM2+ Black
and 4 gb di ram ddr2 1066
it may be usefull in a htpc
or would be too much for that use?
it would see the difference in performance in a HTPC?
i have a
it is enough?
Standard definition content is not going to be a problem with that spec- what codecs are you using (in DVBViewer>Settings>Options>DirectX/DVDoptions>MPEG2 Video decoder, H.264 decoder)?
as divx codec
video decoder: Cyberlink Video/SP Decoder(PDVD9 UPnP)
Decoder Video H.264:Cyberlink H.264/AVC Decoder (PDVD7.x)
Render Video:EVR Vista EnHanced video render
DVD Option
Decoder Video MPEG2:
as divx codec
DVD Option
are good this codecs settings
Try normal Cyberlink PDVD 9 decoder (not UPnP).
