shadowdogg Posted May 27, 2009 Posted May 27, 2009 I am using a DVB-C Card using Virgin Media and when I change channel - in the OSD it would show the next program but in the EPG it would only show the programmes which is currently on and forget the in betweens. any way i could fix this? Quote
dvbrewer Posted May 28, 2009 Posted May 28, 2009 I am using a DVB-C Card using Virgin Media and when I change channel - in the OSD it would show the next program but in the EPG it would only show the programmes which is currently on and forget the in betweens. any way i could fix this? Are you saying you are only getting now and next data? Under settings>options>EPG/Teletext do you have persistent EPG data selected and do not receive epg data unticked? Quote
