rulet Posted May 29, 2009 Posted May 29, 2009 Which driver I have to install before installing DVBViewer for Technotrend TT-budget S2-3200 + CI DVB-S/S2 PCI --- WDM or BDA driver? And should I install the driver together with TT-MediaCenter? Does DVBVier works with all kinds of DiSecs? Quote
Griga Posted May 29, 2009 Posted May 29, 2009 Which driver I have to install before installing DVBViewer BDA And should I install the driver together with TT-MediaCenter? Basically DVBViewer doesn't need the Media Center, but maybe you need/want decoders that are installed with the media center. Quote
rulet Posted May 29, 2009 Author Posted May 29, 2009 And with what DiSecs supporting 4to1 this card works --- anybody uses it? Quote
Griga Posted May 29, 2009 Posted May 29, 2009 Topic moved, because it is obviously not DVB-T related. And with what DiSecs supporting 4to1 this card works DVBViewer supports DiSEqC 1.0/1.1/1.2 with the TT S2 3200. Read more about it here, particularly the "Hints for DVBViewer" sections. The TransEdit DiSEqC capabilities are almost identical with those implemented in DVBViewer Pro/GE. Quote
