diny Posted May 29, 2009 Posted May 29, 2009 Hello downloaded transponder file for ziggo cable tv from the forum when i put it in the transponder list it does not show op in the channel scan. Help Quote
Lars_MQ Posted May 29, 2009 Posted May 29, 2009 Did you put it into the transponders folder in the Configuration folder? Quote
McenterFreak2 Posted May 30, 2009 Posted May 30, 2009 thanks works now I have always wondered why there should be a Program Files Folder and a Configuration folder? If i want to install a plugin, it is in the program folder. If i want to install a transponder file it is in the configuration folder. Why? Quote
Lars_MQ Posted May 30, 2009 Posted May 30, 2009 Because transedit needs to be able to write to the transponder files. Quote
