Dagostino Posted May 30, 2009 Posted May 30, 2009 Hi all, I have a problem with DVBViewer 4.1.1.1. I receive some HDTV channel through DVB-T (TF1 HD, FRANCE 2 HD, M6HD). DVBViewer work very fine but when i record HDTV, the final file only have the sound... no image :'( Do you know where is the problem ? Filters = Cyberlink H264 PDVD 7 and/or 9 Tk you very much for your help !! dago Quote
Griga Posted May 30, 2009 Posted May 30, 2009 the final file only have the sound Maybe just a playback problem. What is the file size? Download TSPlayer from the members area and check if it finds a video stream in the file and displays it in the available streams field. Quote
trifon33 Posted May 31, 2009 Posted May 31, 2009 (edited) Hi all, I have a problem with DVBViewer 4.1.1.1. I receive some HDTV channel through DVB-T (TF1 HD, FRANCE 2 HD, M6HD). DVBViewer work very fine but when i record HDTV, the final file only have the sound... no image :'( Do you know where is the problem ? Filters = Cyberlink H264 PDVD 7 and/or 9 Tk you very much for your help !! dago Hi Dagostino No issue for me with DVBViewer when playing back recorded HD. Pls check DVBViewer player parameters... Right click>View>>filters>> I suspect the H264 codec in use unable to play HD when playing back HD contents. cheers Edited May 31, 2009 by trifon33 Quote
Dagostino Posted June 1, 2009 Author Posted June 1, 2009 Hi Trifon, hi Griga, It's well a playback problem :'( I've installed VLC player (before had the satsuki decoder pack with MPC) and now i can see the images. It's stranged because i use the Cyberlink codec for the record in DVBViewer, codec which is installed when we install Powerdvd. I will try to install another codec. I'll keep you informed Quote
trifon33 Posted June 1, 2009 Posted June 1, 2009 (edited) Hi Trifon, hi Griga, It's well a playback problem :'( I've installed VLC player (before had the satsuki decoder pack with MPC) and now i can see the images. It's stranged because i use the Cyberlink codec for the record in DVBViewer, codec which is installed when we install Powerdvd. I will try to install another codec. I'll keep you informed Test MPC-HC. I don't use it but I think the splitter shoud be able to deal with HD TS files....May be Haali splitter??? Please note the Cyberlink 9 H264 codec included in POwerDVD presently won't work(bug)...old basic version 7 either as no compatible. That one included in Technotrend software for instance. By Edited June 1, 2009 by trifon33 Quote
