Guest t6ti00 Posted May 31, 2009 Posted May 31, 2009 Is there any way to allow DVBViewer to get minimized during recording (if recording has started on fullscreen)? I can only close DVBViewer and recording stops. I have found a difficult way to do minimizing during recording, but is there an easier way can be done from menus with a remote? Thanks. Quote
Devastation Posted May 31, 2009 Posted May 31, 2009 (edited) but is there an easier way can be done from menus with a remote? you can learn a button from your remote with the actionID 16382. This is for minimizing DVBViewer. In the file "actions.ini" in the DVBViewer folder you find all availble commands for DVBViewer. Edited May 31, 2009 by Devastation Quote
