scrambled channels on same trasponder
Good Morning,
we are using Ver. 4.1.1 Client/Server in Vista SP1 with 1 FloppyDtv T/CI(we have tested several FW and DRV), CAM Diablo Light Ver 2.3(we have tested several version of firmware like Underworld,Stealth and Horizon) with a Mediaset Premium (Italy) valid card subsciption.
In clients if i swith from FTA channels in same trasponder(freq.) everything works fine.
In one client if i swith from Scrambled channels in same trasponder(freq.) the other client crash and displays a black screen.
To return to the proper functioning i have to stop and then restart the dvbserver.
This is a bug or something wrong?
Thank you for your reply.
I've just tried a similar configuration but with the recording service. No problems, I even can watch 2 different scrambled channels, though a short inevitable break occurs when switching the other client to different channel (all on the same transponder of course).
Hi Derrik,
i have the same problem also with the recording service.
I spent 2 nights trying everything but the problem is not resolved.
I am beginning to think that the problem is the failure floppydtv:What do you think?
Athos
dunno.. ..pls. add support.zip
  • 3 weeks later...
Hi Derrik,
Sorry for the delay, but i went on vacation.
As requested i will send the file:you can help me?
Athos
