4.1.1 Bug in the wizard
Dagostino
Hi all,
I've found a little problem on the last version with the wizard.
After the screen "Select Hardware", we can run the scan of the channel list. Then we have to select the DVB system (Terrestrial in my case) and after the Source (for me "France"). That works fine but only if i've choosed English as langage at the beginning of the wizard.
If i've selected French, i can select any system, the screen of the source still show the sources for Satellite :
Print screen here :
I've tried some other langages but that works fine.
Solution is to select english, go to scan screen and go back the langage, change to french and now run the test.
Hope it will help
dago
Edited by Dagostino
Found it. There where several problems in the language file. I tried to fix as much as I could find.
Please use the attached language file, It should work.
Fran_ais.zip
