marianh Posted June 4, 2009 Posted June 4, 2009 Hi gyus, When I start DVBViewer it always changes the initial channel to 0, which is as a info channel with color monoscope. In options I have checked to remember the last watched channel so I expect DVBViewer to switch to the last channel at startup. From time to time while watching some channel, DVBViewer automatically changes the channel to a random one (0, 1 or 4) which is very annoying. It seems like the is a process which I already tried to unplugged the keyboard receiver as I though it might be the cause of the problems but it made no change . I am using version 4.1.1 and 4.0.0. I experienced the problem on both of them. Marian Quote
marianh Posted June 5, 2009 Author Posted June 5, 2009 Please post support.zip Here it is. Thanks in advance. Marian support.zip Quote
Devastation Posted June 6, 2009 Posted June 6, 2009 http://www.DVBViewer.info/forum/index.php?...st&p=240131 Was the same problem. It was triggered by the remote-driver. Also can external keyboard events or bluetooth drivers cause the problem. Because you use Win7 there are maybe much more possible causes, but try to find it first at some input device. Also in the DVBViewr.log are some EAccessViolation but they are some days ago so this wouldnt be it. Quote
