karlceasar Posted June 5, 2009 Posted June 5, 2009 (edited) Can't get picture on the HD-channles, the log says: Exit, no channel data, possible no [PMT Scan] or [PMT not found]... Anyone have a solution? Of course the values are according to official figures... so I'm a bit confused. Edited June 5, 2009 by karlceasar Quote
Lars_MQ Posted June 6, 2009 Posted June 6, 2009 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Derrick Posted June 6, 2009 Posted June 6, 2009 ..and the frequencies of corresponding transponders. It could be related to the hardware due to high bandwidth problems. Quote
karlceasar Posted June 9, 2009 Author Posted June 9, 2009 (edited) ..and the frequencies of corresponding transponders. It could be related to the hardware due to high bandwidth problems. I am out travelling why I haven't responded earlier. I've heard some people that have had that problem, but in fact some of these channels do got bandwidth of 25', not only 30' that i assume that you would like to point out. But I know of people stating that everything should work with this card, could perhaps dependend on different revisions but nothing that I've seen any confirm. I'm using following setup: Floppy-DTV S2 card MB: Abit N73-HD with Geforce 7100 chipset GPU: Ati HD4850 CPU: Intel Quad 6600 Ram: 2 GB Sound card: Asus Xonar D2 OS: Vista Ultimate I do consider I have more than enough horsepower under the hood! Edited June 9, 2009 by karlceasar Quote
Lars_MQ Posted June 9, 2009 Posted June 9, 2009 the log says:Exit, no channel data, possible no [PMT Scan] or [PMT not found]... Which log? These messages are not logged by the DVBViewer. Quote
karlceasar Posted August 27, 2009 Author Posted August 27, 2009 Which log? These messages are not logged by the DVBViewer. I solved the problem. Had to chage the modulation for the S2 channels from Auto to 8PSK for each channel with the channel editor. Now it is working great. Quote
