uglyned Posted June 6, 2009 Posted June 6, 2009 Hi, Just wondering if there's any way the recording service can communicate to the DVBViewer client that it is currently recording? I'm worried that when it gets to the end of the night and bed time, and I've usually had some wine by then, it would be too easy for me to pick 'standby' from the exit menu and promptly shut down half way through a recording - because I wouldn't know that anything was recording. Can the recording service activate the 'recording' flag in DVBViewer? Or how about having a 'standby after current recording' option in the exit menu? If nothing is recording it closes now, but if there is something recording it adds a 'standby' action to that timer event? Thanks. Quote
Devastation Posted June 6, 2009 Posted June 6, 2009 When I close the DVBV with the hibernate command and RecService is recording there is no hibernat. So I think it funktions correctly. Be sure to check in the DVBV- RecordingService Options the send timer to, connect to timer list and connect to recording list options. Quote
