No OSD since version 4.1 ?
vef445
I'm using DVBViewer for a long time for sat and TNT receiving.
Yesterday, I had to format my HTPC for many reasons and I have install the last version of DVBViewer.
The problem is that I don't have any OSD now :s I ever try version 4.1 few weeks ago with this same problem (OSD OK with version 3.9.x on the same computer).
I'm using "overlay" in "video renderer" option.
Many thanks for your help!
Config : Nvidia 8300GS, 3500+ Athlon64, WindowsXP Pro...
PS : sorry for my very bad english language :)
I just want to add that when I call OSD menu nothing appened...
I have a strange issue with EPG that is maybe link to OSD problem : EPG infos are writed "behind" video (we can highlight them with the mouse, hard to explain).
When I open the following menu : settings=>options=>OSD=>OSD Menu everything is blank :(
The folder c:\DVBViewer\OSDSkins\Defaut is not empty (many XML files and other).
Thanks for your precious help! :)
I have exactly the same problem (not only EPG info, but also recording scheduler)
sorry, my config :
Asus P5Dlx Dualcore E6750
XP pro
Ati radeon 2600 pro catalyst 9.5 (idem with 8.1)
dualview liteon 17' sony DL40W4000 with Ultramon
Maybe desktopTV Modus aktivated? Rightklick --> view --> Desktop TV
what means blank? If you mean there is no option checked so please check all options.
@laks and @vef445
if this dont help
please post support.zip
Edited by Devastation
In your DVBViewer log I find:
2009-06-11 08:12:03 EListError raised by instance LVTVGuide of class TVirtualStringTree at 00426EA6:Listenindex überschreitet das Maximum (5)
I dont know what it means. Have you a program or plugin called LVTVGuide?
no program and no plugin
I think this happened this morning with bad reception of a crypted channel and CI no decoding, I did'nt see it before, probably no link with "epg watermark"
Check in your DVBViewer program folder (not config), in OSDSkins folder, there should be 'Default' folder and any other Skin you have installed. Now, check in your DVBViewer the location of your configuration folder (in DVBViewer menu - About- Configuration folder), then open windows notepad, open setup.xml in that folder, scroll to bottom, you will see a section OSD, make sure currentOSD points to your preferred OSD skin, if not change it, making sure that skin exists in your OSD folder. Open DVBViewer, if the skin doesn't work yet, change to disabled in options, then reenable it, restart DVBViewer :bounce: .
Edited by dvbrewer
