Access DVB Viewer's Timer/Scheduler With Text Only?
antdude
Hello.
Is there a way to access DVBViewer v4's Timer/Scheduler (add/remove/change) via command line/text mode? I use SSH with cmd.exe and bash (cygwin) on my Windows XP Pro. SP3 box. I can't use GUI due to slow Internet speed.
I tried using Lynx and Elinks for HTTPServer.exe (Web interface), but I can't navigate due to JavaScript and frames. Even editing a configuration file would do.
Thank you in advance. :bounce:
yes with "TV Genial + CMDline 1.2" (Members Section)
http://www.DVBViewer.info/forum/index.php?...st&p=228598
Wow, that's complicated
Finding Audio PID and ServicePID (SID) is complex. There has to be a way to make that easier. In my Favourites.xml file, I have nothing in it except spaces (3 KB file). I do use Channellist though.
I tried running it via SSH with cmd.exe:
D:\winstuff\DVBViewerPro>dvbv_tvg.exe
dvbv_tvg.exe
But nothing happened. I don't even gets it full text help. :bounce: If I run it locally, then I get its GUI with help. I can't have GUI!
Edited by antdude
