ronch Posted June 14, 2009 Posted June 14, 2009 Hello, I have HvR-4000 and no dvb-t (only) signal with third parties softwares like DVBViewer and dvbdream. The important part is that it has run smoothly with a vista config and trouble appears with another config under XP SP3. Another point is that it runs fine with dvb-s/s2 and dvb-t too but only with WinTV app. I tried a lot of things and I'm thinking that SP3 is the problem but i ask the question before trying to install vista or xp SP2 which is boring me... thanx ! Quote
ronch Posted June 14, 2009 Author Posted June 14, 2009 sorry i forgot the config file. and to be exact, cause my previous message is not very clean, everything works correct except for the dvb-t part with DVBViewer (and transedit). Is it possible that the terrestrial tuner is "locked" and that only wintv app is able to unlock it ? support.zip Quote
ronch Posted June 15, 2009 Author Posted June 15, 2009 ok thanx for answering but issue is solved ! if it can help, for dvb-t in france the offset is +167 under vista and center (000) under XP. Quote
PeterF Posted June 15, 2009 Posted June 15, 2009 ok thanx for answering but issue is solved ! if it can help, for dvb-t in france the offset is +167 under vista and center (000) under XP. and therefore there is a transponderlist called "France.ini" in the Settings with this offset included, and who knows from your question that you are in France and need this one. PeterF Quote
