Abits Posted June 14, 2009 Posted June 14, 2009 (edited) Its only Waiting I have last version of DVBViewer, and dvb service support.zip Edited June 14, 2009 by Abits Quote
Lars_MQ Posted June 14, 2009 Posted June 14, 2009 explain what you are doing. the service does not find any fitting hardware, so either your setup is wrong or your hardware is in use by another program. Quote
Abits Posted June 14, 2009 Author Posted June 14, 2009 explain what you are doing. the service does not find any fitting hardware, so either your setup is wrong or your hardware is in use by another program. Try this, maybe this work support.zip Quote
Abits Posted June 14, 2009 Author Posted June 14, 2009 In plugin i have VRPlugin and AudioRecorder-plugin I use DVBViewer Recording Service 1.5.0.2 In settings i have use webserver 94.139.72.48 port 80, streamserver port 7522, interface 94.139.72.48 port 8889, popcorn hour on interfce is 94.139.72.48 Same in server: 94.139.72.48. But this should have not with the timer? Quote
Abits Posted June 14, 2009 Author Posted June 14, 2009 In EPG i select a program to the timer, i push send to pvr, in the timer i see the program i change and timer action is record, but nothing happens. Only waiting. i try to change to videorecorder pluging in timer action, but the same problem. Quote
Abits Posted June 14, 2009 Author Posted June 14, 2009 (edited) Ok, i get to work if i use videorecord plugin in default recording action settings. But then does not time before example 5 minutes and nothing in http://94.139.72.48/ Its only work with videorecord plugin, not default recording Edited June 14, 2009 by Abits Quote
