Can't display Chinese characters in the pop-up channellist.
ter9999
The popup channellist on the right is very convenience for me to select different channels than using OSD. But it can't display Chinese characters correctly. While in the bottom status bar, the characters can be displayed correctly.
Could you please add the Chinese char support in the popup channellist? Please see the snapshot taken below.
could please post the channels.dat file? I'll take a look at it.
Please find the channels.dat file attached.
the OSD does display the channel names correctly?
No, the channel names in OSD still can't display Chinese charset correctly. In fact, most of users in our forum don't like to use OSD, they like the popup list.
