Hauppauge WinTv NOVA-USB-t
JPV1961
Pinnacle tv-card from my htpc went broken and I found from storage old Hauppauge WinTV USB Nova-t DVB-T tuner. I got it work with WinTV software but not in DVBViewer. What could be the reason or could it be so that this (pretty old lookin) tuner is not suitable at all?
BR; JP
BR; JP
Did you download the latest drivers (remove old first)?
Is it the WinTV Nova-T USB or the Nova-T-USB2?
The Nova-T USB (white and blue case) does not support BDA and cannot be used with DVBViewer. It will only work in the original TechnoTrend-derived software.
Mine is plain USB not USB2 so no way to get it work..:) Thanx for the info. Seems so that I need to order new tv-card.
-JP-
The Model 294 works great for me. If you're not in a hurry, keep an eye on both Play and Amazon as they seem to both drop the price from around £30 to £14.99/£15.99 every so often for a week or so. I've seen them do this twice over the last 3 months... Hence why I have 3 of these B)
http://www.amazon.co.uk/exec/obidos/ASIN/B000F8RPQE
http://www.play.com/PC/PCs/4-/3326726/Haup...94/Product.html
Edited by Rob100
