evgen_ln Posted June 17, 2009 Posted June 17, 2009 Hello. Tell me please, where I was mistaken. Why this code adds only last EPGItem from EPGCollection to the DVBViewer EPGengine . var EPGCollection: IEPGCollection; NewEPGItem, EPGItem:IEPGItem; FAddEPG: IEPGAddBuffer; chan: IChannelItem; chan_new: IChannelItem; temp: String; i,a: integer; time: TDateTime; begin FAddEPG:=FEpgMgr.AddEPG; chan:= FChans[FChans.GetbyChannelname('Discovery HD (rus)')]; chan_new:= FChans[FChans.GetbyChannelname('M1')]; if (chan <> nil) then if FEpgMgr.HasEPG(chan.EPGChannelID) then begin Memo1.Lines.Add(' '); Memo1.Lines.Add(chan.Name); Memo1.Lines.Add(' '); EPGCollection:=FEpgMgr.Get(chan.Tuner.SID, chan.Tuner.TransportStreamID,Today,Tomorrow); For i:=0 to EPGCollection.Count-1 do begin EPGItem:=EPGCollection.Item[i]; if EPGItem <> nil then begin Memo1.Lines.Add(DateTimeToStr(EPGItem.Time)+ ' ' +EPGItem.Title + ' ' + inttostr(EPGItem.EPGEventID)); NewEPGItem:=FAddEPG.NewItem; NewEPGItem.SetEPGEventID(chan_new.Tuner.SID, chan_new.Tuner.TransportStreamID); NewEPGItem.Charset:= EPGItem.Charset; NewEPGItem.Content:= EPGItem.Content; NewEPGItem.Description:= EPGItem.Description; NewEPGItem.Duration:= EPGItem.Duration; NewEPGItem.Event:= EPGItem.Event; NewEPGItem.Time:= EPGItem.Time; NewEPGItem.Title:= EPGItem.Title; FAddEPG.Add(NewEPGItem); FAddEPG.Commit; end; end; FAddEPG.Commit; end; Quote
Lars_MQ Posted June 17, 2009 Posted June 17, 2009 You need to set the (per channel) unique eventID for the item, otherwise the Viewer won't accept it. I simply use in such a case: NewEPGitem.eventID:=EPGItem.eventID; Should work for you, since you seem to use a different EPGChannelID (aka badly named EPGEventID). Quote
