freddie02 Posted February 25, 2004 Posted February 25, 2004 Hello to all of you, my problem is the following: after using the DVBViewer I can´t enable my screensaver. Also after resetting the computer I can´t reactivate any screensaver. Sure that I disabled the button "prevent screensaver" (in german: Verhindere Bildschirmschoner). Several times I have choosen an other screensaver - always with the same effect. BUT: Sometimes (only sometimes!!!) the screensaver works again once or twice; and after that I get the same bug. I´m using an Pentium 4, 3,0 GHz with hyper-threading Is there anyone who knows the effect and who can help me? Thanks in advance. freddie Quote
Klausing Posted February 25, 2004 Posted February 25, 2004 Please read this and give us needed informations Quote
freddie02 Posted February 25, 2004 Author Posted February 25, 2004 Hello, thanks for answering. Here are the requested informations: MEDION (Aldi Titanium 8080XL) Pentium 4 CPU 3,0 GHz Board: MSI MS-6747 512 MB Ram Graphik: ATI Radeon 9800 Pro Win-XP Home SP1 TV: TechniSat SkyStar 2TV using DVBViewer 2.0 R3 with Marfi´s renderer 1.1 Hope these are the informations you need. Attached are the files setup.ini and DVBViewer.log Thank you freddie Setup_DVBlog.txt Quote
Klausing Posted February 25, 2004 Posted February 25, 2004 Do you have this problem since R3 or exist this problem on your PC since earlyer versions? What happens if you start the screensaver with click on test in the screensaver options during the Viewer runs? Quote
