Filters inside DVBViewerGE vs those of DVBViewerPro
fundom
With DVBViewerPro installed, I have just been unzipping the downloaded DVBViewerGE folder & start using it as such. It is only recently that I observed that GE has its own filters, different from those in DVBViewerPro. Am I supposed to use different set of filters for these versions OR can GE share the filters inside PRO version?
The filter effectively in use depends on which one were registered last in Windows registry (with regsvr32 or "Register_Filters.exe" or the similar .bat), so the "PushSource.ax" colled from either GE or Pro can reside in both the folder and both use always the same...
If you have problem with the filter you can simply register again the PushSource filter from the folder you want...
