Dadag Posted June 18, 2009 Posted June 18, 2009 Hi, Some HD terrestrial and satellite (5°W) channels are using now DD+ as audio channel, DVBViewer seem doesnt identify correctly, DVB source identify as AC3. Cyberlink PDVD7 and PDVD8 have codec for EAC3 but output no sound. Thanks for update. Quote
Tjod Posted June 18, 2009 Posted June 18, 2009 You need Sonic Cinemaster Audio Decoder 4.3.0 or ffdshow (rev2322 or newer) as AC3 decoder. http://www.DVBViewer.info/forum/index.php?...471&hl=EAC3 Quote
Dadag Posted June 20, 2009 Author Posted June 20, 2009 You need Sonic Cinemaster Audio Decoder 4.3.0 or ffdshow (rev2322 or newer) as AC3 decoder. http://www.DVBViewer.info/forum/index.php?...471&hl=EAC3 I have tried ffdshow beta6 rev 2527 as audio codec AC3 for DirectX (XP SP3) no problem for AC3, but DVBViewer Pro 4.1.1 crash on libavcodec immediatly receiving E-AC3 stream. I can try one more recent revision. I cant get the Sonic one now. I dont understand why Cyberlink PDVD 7.x Ultra (PDVD 8 have also E-AC3 compatibility) can play DD+ with HD-DVD and not with DVBViewer. Quote
Griga Posted June 20, 2009 Posted June 20, 2009 It has been successfully tested with rev2322: http://www.DVBViewer.info/forum/index.php?...st&p=220762 Quote
Dadag Posted June 20, 2009 Author Posted June 20, 2009 (edited) juste tried ffdshow rev 3009 from 18/06/2009, it work perfect for audio but send 8 lines magenta over the HDMI in the image when E-AC3 (converted to AC3) No problem when receiving AC3. Edited June 21, 2009 by Griga useless repetitions removed Quote
Dadag Posted June 20, 2009 Author Posted June 20, 2009 (edited) juste tried ffdshow rev 3009 from 18/06/2009, it work perfect for audio E-AC3 and convert to PCM (2 spkr) Edited June 21, 2009 by Griga useless repetitions removed Quote
