Advice for power management with DVBViewer
uglyned
I'm using DVBViewer with XP SP2 on a Gigabyte 780G board with an AMD 5050e chip.
DVBViewer isn't coping too well when the box returns from standby. I put it into standby straight from DVBViewer and when I come back, DVBViewer takes a little persuading in order to work properly.
Sometimes it reports that the Recording Service isn't running and leaves a black screen, other times it just leaves a black screen.
Does anybody have any advice on how I could get it running a little smoother? DVBViewer is all I use the PC for.
Thanks.
Thanks, I will. To be honest I didn't know if it even was a problem - and if there was a problem I was blaming Windows more than DVBViewer.
It's a dual tuner PCI-e card by Pinnacle. I'll post a support.zip up when I get chance. Thanks.
