Tom Wideroe Posted June 19, 2009 Posted June 19, 2009 Hello I have buildt in a touch screen in my kitchen. This touch screen controls whole house audio (6 zones), music + radio, is used for pictures, weather updates etc. For some time I've also tried to implement TV by using DVBViewer. DVBViever is started in pause mode in background, and my application runs on top of it, and controls DVBViewer through sendmessage interface. When viewing TV, my application puts an almost invisible form over it (AlphablendValue := 1), and when I touch this form, the control buttons are shown (while DVBViewer runs in background) My problem is however that reception of TV signals get jagged. I've tried different video renderes, different modes (VMR7, VMR9) etc. but it does not seem to help. When running DVBViewer as stand alone front end, everything works fine... I suspect it has something to do with my almost form in front of DVBViewer.. Anybody have any suggestions on how to solve this? Thanks, Tom Quote
Tjod Posted June 19, 2009 Posted June 19, 2009 If you don't use the OSD try disabling it (Options > OSD > disable), it will disable some other connected functions as well. It is although a layer in front of the picture. Or try the VMR Fix (Options > DirectX). Quote
