Lamigo Posted June 23, 2009 Posted June 23, 2009 Hi, Is it possible to enable CAM with IPTV network device like a true DVB tuner? My french ISP Orange is using viaccess 3.0 for pay tv. I would want to use my USB CI player... Quote
Lars_MQ Posted June 23, 2009 Posted June 23, 2009 it is theoretically possible. I have to think about it. Quote
ariken Posted September 28, 2009 Posted September 28, 2009 It will be also useful if you simply stream the dvb channels over ip. Do you think is possible to add this feature? Thank you it is theoretically possible. I have to think about it. Quote
Tjod Posted September 28, 2009 Posted September 28, 2009 What is the difference between your idea and the current streaming possibility (NetStrem plugin, DVB Server, Streaming via Web-interface and Recording Service)? http://en.DVBViewer.tv/wiki/Category:DVBVi...cording_Service Quote
ariken Posted September 28, 2009 Posted September 28, 2009 What is the difference between your idea and the current streaming possibility (NetStrem plugin, DVB Server, Streaming via Web-interface and Recording Service)?http://en.DVBViewer.tv/wiki/Category:DVBVi...cording_Service DVBViewer is a great piece of software, but i don't like Windows as a server for ANYTHING I wrote a linux daemon that will stream DVB-S/T channels over the LAN and I use DVBViewer as client using IPTV device. Last week i brought a Wintv-CI but I'm able it to use it only with the hardware receiver installed. Quote
