aydan Posted June 24, 2009 Posted June 24, 2009 Hi, DVBViewer seems to have problems playing recordings where the satellite signal was lost for example due to bad weather. The audio and video will be severely out of sync. Watching the same video in WMP9, the A/V sync is better but far from good. Is there a way to correct this? Right now I'm using VirtuaDUB and syncing the audio by hand while watching. I can provide the offending recordings if you need them. Bye Aydan Quote
Griga Posted June 24, 2009 Posted June 24, 2009 http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
aydan Posted June 25, 2009 Author Posted June 25, 2009 You know, I don't see where this has anything to do with my current configuration and also I didn't post it as a bug. I've had this problem with previous versions as well. But here you go: support.zip And I tried serching for this as well. Didn't find anything relevant though. Quote
