ytulpan Posted June 24, 2009 Posted June 24, 2009 Hello, I cannot find the Graphselector plugin in the download section. Where is it ? I would like to try to play in graphedit with various graph combinations. Is it possible to use the DVBSource demux ? I do not seem to be able to provide a file source for it. Does it work only inside DVBViewer ? Thanks Quote
Tjod Posted June 25, 2009 Posted June 25, 2009 Since version 4.0 there is no Graphselector Plugin support any more. The reason is this new feature: New: In Options -> DirectX you can configure two sets of different Videodecoders/Videorenderers (Video A/;) and Audiodecoders/Audiorenderers (Audio A/:). Switching between these settings can be done manually or automatically:1) Manually: You find the commands in the main menu -> Settings or you can define keys in Options -> input for it. Switching between the sets does trigger a rebuild graph. 2) Automatically: In Options -> DirectX you find on the tab sheet "Video B" and "Audio B" edit boxes labeled "Auto B-Conditions". The following conditions (if you use more than one, separate them by a "," without the ") can be used here: File (file playback) Video (Playback with Video) H.264 (H.264 Video) MPEG2 (MPEG2 Video) DVBSource (DVBViewer Filter is used) A Slash / in front means "not" (Negation, example: /File = TV/Radio (not file)). The automatic switching to Set B happens, if all listed conditions are met, otherwise the DVBViewer uses Set A. If you define auto-conditions the manual switching is disabled. Some examples: Using Vista you want for H.264 Video the EVR otherwise the Overlay Mixer to be used. In Video A you set the Overlay Mixer, in Video B you select EVR and as condition you set "H.264". H.264-Playback with the DVBViewer Filter should use the Cyberlink Decoder (Video A), otherwise ffdshow (Video B ), this is useful for H.264 in MKV-file, which the DVBViewer Filter doesn't handle. The needed condition would be "H.264,/DVBSource". Playback of video files should use ReClock Audiorenderer, for the rest (TV/Radio and audio only playback) Default DirectSound (Audio A). In Audio B you set ReClock as renderer and use the condition "Video,File". Which is not possible with the Graphselector Plugin support. Quote
