chew6acca Posted June 25, 2009 Posted June 25, 2009 I am on version 3.9.4.0 of DVBViewer pro. I have spent 2 days trying to find the download for 4.1. Do I have to pay again for the latest version? Thanks! Quote
Tjod Posted June 25, 2009 Posted June 25, 2009 I have spent 2 days trying to find the download for 4.1. It is the same place as the old Version the Members Section http://www.DVBViewer.com/members/ Do I have to pay again for the latest version? No Quote
chew6acca Posted June 25, 2009 Author Posted June 25, 2009 It won't let me in. I have reset my password. I can log into the forum. I have tried ie, ff, opera, chrome. Quote
Lars_MQ Posted June 25, 2009 Posted June 25, 2009 Use the data you received when you purchased the DVBViewer Pro. The forums userdata has nothing to do with the membersarea. Quote
McenterFreak2 Posted June 25, 2009 Posted June 25, 2009 Use the data you received when you purchased the DVBViewer Pro. The forums userdata has nothing to do with the membersarea. And that is, in my opinion, the most stupid thing in this forum/site Quote
chew6acca Posted June 25, 2009 Author Posted June 25, 2009 (edited) I tried that too - I have emailed Bernd... Edited June 25, 2009 by chew6acca Quote
Benarty Posted June 26, 2009 Posted June 26, 2009 Weird, I never had problems tgo access the members site, except when its down or isp problem. Are you sure that you entered the correct e-mail address and correct password? Then it should work. Quote
hackbart Posted June 26, 2009 Posted June 26, 2009 If you send us an email with the information that you lost your key, you have to give us at least the email adress you where using for registering the software - otherwise we can not help you. Christian Quote
chew6acca Posted June 28, 2009 Author Posted June 28, 2009 (edited) I was using the wrong email account. My fault - sorry. Edited June 28, 2009 by chew6acca Quote
