satboy Posted June 27, 2009 Posted June 27, 2009 I'm a happy user of the ImportXLMTV on my HTPC. Great Job. Many Thanks to the Author of this program. Now i've tested the configuration DVBServer (on the HTPC) / DVBViewer (on my other PC). After read many posts on this forum, and some try, it works perfectly. After copied Channel.dat, Favourites and Channels Logos (from my HTPC) to my PC, I have same things on both HTPC and PC. But I don't know where (wich is the destination file) the ImportXLMTV program imports the TVGuide.xml into DVBViewer. In other words, after imported the TVGuide.xml on my HTPC, is there a file I can copy to my PC to have the same 7 days EPG ? (I don't think is the Epg.dat). What is possible to do ? (Sorry for my poor English) Thank You Quote
Gioxy Posted June 28, 2009 Posted June 28, 2009 I don't think is the Epg.datWhy not? Really is it (obviously you have to do it with DVBViewer shutted down!) What is possible to do ?You can use the Recording Service instead of DVBServer (with many more advantage...) in conjunction with DVBViewer v. 4.1.1.0 or greater: in "Settings / Options / Recording Service" you can easily update the PC EPG from the HTPC one... Quote
satboy Posted June 28, 2009 Author Posted June 28, 2009 Thank You very much, Gioxy It works perfectly ! (I don't know why but I had seen a very small (some Kb) Epg.dat. Now I have some Mb Epg.dat). As soon as possible I will try the Recording Service. I think to understand from you that will be a better choice for me. Bye Quote
Gioxy Posted June 28, 2009 Posted June 28, 2009 a better choice for meYuk! ...for all! You can find all info and how to in the Recording Service wiki page... Quote
