Raw DiseqC support for KNC1 cards?
ter9999
I see in the latest beta 4.2.0.11 zip file, there is a dll file called KNCBDACTRL.dll, what's the use for this file?
I have the KNC1 DVB-S2 card, it can't support C-band reception even using there latest driver. So using together with this dll file, the KNC1 card can receive C-band?
Thanks!
•Add: Raw DiseqC support for KNC1 cards. You must use the dll enclosed in the beta release.
Attention: The DLL is NOT compatible with the DVBViewer Pro release version or the DVBViewer Recording Service!
No. It just means that DiSEqC 1.1 and 1.2 are supported for KNC products.
Edited by CiNcH
Thank you very much for your information. I tried everything in DVBViewer to let KNC1 to lock C-band signal, but all failed. The latest KNC1 BDA driver says they added C-band reception support, but DVBViewer can't make it.
So I may think this is a DVBViewer issue.
Version: 2.0.506.0
Größe: ca. 1,2 MByte
Datum: 06.05.2009
Wichtig: Beachten Sie bitte unbedingt die in diesem Download enthaltenen Installationsinformationen und Hinweise!
Der BDA-Treiber eignet sich für den Betrieb mit TV-Software anderer Anbieter, welche diesen Treiberstandart unterstützen, z.B. Microsoft MCE oder TVcentral. Nähere Informationen sind in dem Treiber-Download enthalten. Die Unterst黷zung von Beta-Betriebssystemen kann nicht garantiert werden.
Änderungen:
Korrekturen bei Standby
Implementierung von C-Band und DBS-Band
Unterst黷zung unter Windows 7 Beta
AFAIK we had this discussion already and the result was that KNC sees things differently than the DVBViewer devs...
Edited by CiNcH
Yes, I remembered we have talked this before. It's strange that KNC1 BDA driver doesn't comply with the DVB standards. I wrote to them but no response and I don't know how to proceed now...
I'm thinking DVBViewer doesn't want to change its code for KNC1 card to receive C-band... Maybe I need to discard the KNC1 card.....
Disappointed..
Edited by ter9999
