Problem with the recording program
RiSaMa
Good morning, I commented that I have a problem in the DVBViewer and Windows 7 x64 (7201).
I schedule a recording and it works fine if the program is running. In contrast, if the program is shut down, just when it should not turn to get recording ... Any solution?
Another thing ... When recording a program (high definition) set up the log says I have no error or discontinuity. What does it mean ... as demuxeo (as separate video and audio) that ts?
Thank you very much
Nobody can tell me how to solve the problem with the recording program?
The program has to be left running, otherwise the timer won't work. Simple as that.
This problem can be solved by the DVBTaskScheduler, DVBViewerRecordingService or EventGhost.
Regards
Stefan
  • 1 month later...
Regards
Stefan
Hi ,
I have the same problem, running windows 7 (32-bits)
Ihave try with DVBTaskScheduler and DVBViewerRecordingServices.
The DVBViewer starts but no picture and no channel select.
If I manually change the channel it starts recording.'
In xp and vista works fine.
Helio
  • 1 month later...
Hi, for the record. I have the same problem with a new installation of the full release of windows 7 64bit. My previous OS - vista business 32bit, worked without issue.
Chritian and I both work with W7 32 bit and have no problems.
  • 3 weeks later...
I have the same problem. I am using the latest DVBViewer 4.2.1.0 and Taskscheduler v2.2.3.
and Windows XP Pro.
DVBViewer starts and record but no channel are selected, so nothing are recorded!
Earlier I used DVBViewer 3.9.1.0 and Taskscheduler 2.1.0 and then it worked!
Does anyone know whats wrong? The new DVBViewer or Taskscheduler or both ?
Or do have do some tests?
/Brian
Now I have tested Taskscheduler v2.1.0 with DVBViewer 4.2.1.0 and it doesn´t work.
So I have to turn back to DVBViewer 3.9.1.0.
Hope you soon can solve this problem.
/Brian
