I don't see the plugins menu!?
TommyN
I just purchased the DVBViewer Pro version and I have a problem.
I'm not getting a "plugins" menu between the "Settings" and "About" menues.
When going to "About->Info->Versions Info" I can see several plugins loaded.
Any help would be greatly appreciated.
Thanks,
Tommy
pleas post the support.zip
Attached is the support.zip. When running the support tool the sat cable was connected to my DM500 and DVBViewer was not running.
I'm on Win 7 RC (x64bit)
Thanks,
-Tommy
I reinstalled the sw and forgot to add the plugins when creating the .zip file.
I tried again and now it seems to be ok at least I see the plugins menu :D
-Tommy
