Parental control
TommyN
I found this section in the 4.0 reease notes:
New: CI: automatic parental control PIN (Jugendschutz PIN) entry. The PIN must be put into the userdata.xml:
CODE
<section name="CAM">
<entry name="PIN">1234</entry>
</section>
Does anyone know what effect this will have? I added this to my userdata.xml file and restarted DVBViewer but did not notice any changes.
I would like to set parental control on some of the channels only. It would be great if it was possible to set it based on time of day as well.
Anyone know if this is possible? I looked at the chapter headlines in the manual and it did not mention parental control as far as I could see.
Cheers,
-Tommy
Pretty sure this is to automatically enter control code into CI CAM not the way you imagine it... So it won't have any effect unless you have CAM that requires parental code entering.
Edited by Valts
