Can't watch scrambled channels
kharder
I have a problem with watching scrambled channels. When I try to, the screen just goes black but the meter that shows the strength of the signal changes and shows the strength, but nothing else appears. When I watch an unscrambled channel, I see all information and icons.
I have tried to reinstall windows xp severel times but with the same result. Now I will try with vista to see if that changes anything.
My tuner is a floppydtv, and what's funny is, that if I use the utility that comes with the tuner, everything works.
What other information do you need and how do I get it for you?
Thanks for your help !
Hi again,
Here is the requested files. I just done a complete reinstall of xp so there should not be anything which shouldnt be on the computer.
// Kenneth
I think the problem is the CAM. It should be a SMIT CAM
Thanks for the reply, but I don't think the cam is wrong. My provider uses viaccess and I bought my cam from them here in Denmark. One thought, could be that the strength of the signal is to low? But then again every other program is working and I can watch tv.
// Kenneth
Now I think I solved the problem. On floppydtv, the CI program has to be started. I can't figure out if it was me who didn't think or it was the lack of information from Digital-everywhere or the programers of DVBViewer.
But one thing I got from this, was an excuse for getting an new pc... :bye:
