coolworm Posted March 2, 2004 Posted March 2, 2004 When i scan channels with DVBViewer v2r3 the program shows me that found 90 channels for example when i go to see the channel theres only 20 with radio stations! why is that?? Quote
Griga Posted March 2, 2004 Posted March 2, 2004 If you scan without a transponderlist by using a 5 MHz step size, channels may be found several times, e.g. at 12395 MHz, 12400 Mhz, 12405 MHz due to the limited selectivity of the SS2 tuner. The DVBViewer counts them all, but automatically eliminates duplicates in the channellist. Griga Quote
Griga Posted March 2, 2004 Posted March 2, 2004 Which transponder did you scan? If there is a bug, more detailed facts would help to fix it. Quote
coolworm Posted March 2, 2004 Author Posted March 2, 2004 when i scan Eurasiasat 1 have to be digital channels 49 free 2 with encode,DVBViewer can all of them but when i go to channel list i can see only 6! i try with progdvb and i can see them all! Quote
